									3D-Druck - CNC-Fräsen für Gewerbe, Bildung und Hobby Forum				            </title>
            <link>https://www.stepcraft-systems.com/forum/3d-druck</link>
            <lastBuildDate>Sat, 20 Jun 2026 01:00:05 +0000</lastBuildDate>
                        <title>Extruder Stepper Choice</title>
                        <link>https://www.stepcraft-systems.com/forum/3d-druck/extruder-stepper-choice</link>
                        <pubDate>Thu, 13 Nov 2025 01:54:10 +0000</pubDate>
                        <description><![CDATA[Hi All,
I&#039;ll be starting to build my V-Core 2.0 soon, and am still mulling over what extruder/hot end I&#039;ll be using.
I&#039;ll definitely go with a Bondtech BMG, as I&#039;m very pleased with the on...]]></description>
                        <content:encoded><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">I'll be starting to build my V-Core 2.0 soon, and am still mulling over what extruder/hot end I'll be using.</p>
<p dir="auto">I'll definitely go with a Bondtech BMG, as I'm very pleased with the one I'm using already, and there's a fairly good chance I'll spend the money and go with the Slice Mosquito hot end as I like how it bolts up to the BMG.</p>
<p dir="auto">I was going to go with some small steppers I've got here off a Zortrax M200 extruder, as they're compact and work well at 500mA, but I don't have any specs on them at all. I'll assume they are 1.8 deg steppers.</p>
<p dir="auto">Does anyone have any recommendation, possibly from "<a href="https://www.stepperonline.co.uk" target="_blank" rel="noopener">Stepperonline</a>" in Australia that would work for a large corexy machine in direct drive configuration, using the BMG/Mosquito combo mentioned above? Do I need 1.8 or 0.9 deg for the extruder? I would prefer a plug on the stepper, just for ease of working on the hot end assy.</p>
<p dir="auto"><span>I've got the exact X, Y and Z steppers you used in your corexy. They look good and were cheap/ex stock from Steppersonline in OZ.</span></p>]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/3d-druck">3D-Druck</category>                        <dc:creator>samlevy0515</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/3d-druck/extruder-stepper-choice</guid>
                        <title>Mini PCB v2-Netzteil zur Verwendung mit Nema17</title>
                        <link>https://www.stepcraft-systems.com/forum/3d-druck/mini-pcb-v2-netzteil-zur-verwendung-mit-nema17</link>
                        <pubDate>Tue, 27 May 2025 06:09:49 +0000</pubDate>
                        <description><![CDATA[Hallo zusammen,Bitte entschuldigen Sie meine Unwissenheit, da ich ein absoluter Neuling bin.Nachdem ich auf YouTube einen Beitrag gefunden hatte, in dem 3D-gedruckte GEMs beschrieben und vor...]]></description>
                        <content:encoded><![CDATA[<p>Hallo zusammen,<br />Bitte entschuldigen Sie meine Unwissenheit, da ich ein absoluter Neuling bin.<br />Nachdem ich auf YouTube einen Beitrag gefunden hatte, in dem 3D-gedruckte GEMs beschrieben und vorgeführt wurden, habe ich mich eingehend mit den Einzelheiten von OnStep befasst und einen DIY-GEM-Ständer gebaut.<br />Ich werde meine Reise mit Version 2 der Mini-Platine fortsetzen. Ich habe die Platine von EasyEDA und die Teileliste wurde bei zwei Online-Shops bestellt (fast genau wie auf der EasyEDA-Website aufgeführt).<br /><br />Ich habe zwei <a href="https://www.oyostepper.com/goods-319-Nema-17-Stepper-Motor-L%3D39mm-39Ncm-0018-deg-168A-27V-with-100-1-Planetary-Gearbox.html" target="_blank" rel="noopener">Nema17-Schrittmotoren</a> mit 100:1-Planetengetrieben von Oyostepper gekauft.Mir ist aufgefallen, dass der Motor eine Nennspannung von 2,7 V und 1,68 A pro Phase hat.<br />Ich überlege, das OnStep Mini PCB v2 mit 12 V zu betreiben (weil ich einen anderen Motor mit einer Nennspannung von 12 V kaufen möchte), bin mir aber derzeit nicht sicher.<br />Muss ich die Eingangsleistung ändern oder dem Stromkreis einen Spannungsregler hinzufügen, um diese Motoren zu verwenden?</p>]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/3d-druck">3D-Druck</category>                        <dc:creator>Orchid</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/3d-druck/mini-pcb-v2-netzteil-zur-verwendung-mit-nema17</guid>
                        <title>Schrittmotor mit hoher Beschleunigung ausgewählt?</title>
                        <link>https://www.stepcraft-systems.com/forum/3d-druck/schrittmotor-mit-hoher-beschleunigung-ausgewaehlt</link>
                        <pubDate>Fri, 09 Aug 2024 09:31:53 +0000</pubDate>
                        <description><![CDATA[Ich brauche eine Anleitung. Ich möchte die Beschleunigung meines 3D-Druckers verbessern, indem ich die Nema17-Schrittmotoren durch Schrittmotoren mit höherem Strom austausche. Irgendwelche V...]]></description>
                        <content:encoded><![CDATA[<div class="lRu31" dir="ltr"><span class="HwtZe"><span class="jCAhz ChMk0b"><span class="ryNqvb">Ich brauche eine Anleitung. Ich möchte die Beschleunigung meines 3D-Druckers verbessern, indem ich die Nema17-Schrittmotoren durch Schrittmotoren mit höherem Strom austausche. Irgendwelche Vorschläge, worauf ich achten sollte?</span></span><span class="jCAhz ChMk0b"><span class="ryNqvb"> </span></span></span></div>
<div class="lRu31" dir="ltr"><span class="HwtZe"><span class="jCAhz ChMk0b"><span class="ryNqvb">Z. B. Hohe oder niedrige Induktivität?</span></span><span class="jCAhz ChMk0b"><span class="ryNqvb"> </span></span></span></div>
<div class="lRu31" dir="ltr"><span class="HwtZe"><span class="jCAhz ChMk0b"><span class="ryNqvb">Hohe Induktivität bedeutet tendenziell ein hohes Drehmoment ... aber dies ist eine 3D-Druckeranwendung, also ... sollte ich beim Vergleich von Schrittmotoren auf hohe Ströme und niedrige(re) Induktivität achten?</span></span><span class="jCAhz ChMk0b"><span class="ryNqvb"> </span></span></span></div>
<div class="lRu31" dir="ltr"><span class="HwtZe"><span class="jCAhz ChMk0b"><span class="ryNqvb">(Ich verwende einen modifizierten Creality CR10S (300 x 300 x 400 H-Rahmen mit V-Nut-Schienenprofil 2020/2040) </span></span></span></div>
<div class="lRu31" dir="ltr"><span class="HwtZe"><span class="jCAhz ChMk0b"><span class="ryNqvb">Die Schrittmotoren scheinen 800 mA zu haben … einige Quellen sagen 1000 mA (1 A) </span></span></span></div>
<div class="lRu31" dir="ltr"><span class="HwtZe"><span class="jCAhz ChMk0b"><span class="ryNqvb">Ich habe eher versucht, etwas mit einem richtigen Datenblatt zu bekommen. </span></span></span></div>
<div class="lRu31" dir="ltr"><span class="HwtZe"><span class="jCAhz ChMk0b"><span class="ryNqvb">Die Laufwerke sind TMC2209 (bis zu 2 A). Die Schrittmotoren werden sehr heiß (und sie befinden sich in einem Gehäuse und ich verwende ein beheiztes Bett (750 W) und überlege, eine Kammerheizung mit 400 W hinzuzufügen, damit sie in einer sehr warmen Umgebung laufen und offensichtlich stundenlang am Stück laufen.</span></span></span><span class="ZSCsVd"></span>
<div class="OvtS8d"> </div>
<div id="ow14625"> </div>
</div>
<div class="UdTY9 WdefRb" aria-hidden="true" data-location="2">
<div class="kO6q6e"> </div>
</div>
<div class="XL3Kf XExWNc">
<div class="a8FIud">
<div data-show-delay-ms="250" data-append-to-body="false" data-propagate-tooltip-mouseover-events="true" data-anchor-corner="bottom-end" data-enable-skip-handler="false" data-popup-corner="top-end">
<div class="dig2sb"> </div>
</div>
</div>
</div>
<div class="ebT7ne VOLvac sMVRZe">
<div class="F0pQVc"> </div>
</div>
<div class="VO9ucd">
<div class="aJIq1d" dir="ltr" data-language-code="de" data-language-name="德语" data-text="Ich brauche eine Anleitung. Ich möchte die Beschleunigung meines 3D-Druckers verbessern, indem ich die Nema17-Schrittmotoren durch Schrittmotoren mit höherem Strom austausche. Irgendwelche Vorschläge, worauf ich achten sollte?
Die Schrittmotoren werden sehr heiß (und sie befinden sich in einem Gehäuse und ich verwende ein beheiztes Bett (750 W) und überlege, eine Kammerheizung mit 400 W hinzuzufügen, damit sie in einer sehr warmen Umgebung laufen und offensichtlich stundenlang am Stück laufen." data-crosslingual-hint="" data-location="2" data-enable-toggle-playback-speed="true" data-results-count="1" data-result-index="1"><span data-irrelevant-id="ucc-1373"></span>
<div class="m0Qfkd"> </div>
</div>
</div>
<div>
<div data-show-delay-ms="250" data-append-to-body="true" data-propagate-tooltip-mouseover-events="true" data-anchor-corner="bottom-left" data-enable-skip-handler="false" data-popup-corner="top-left">
</div>
</div>
<div>
<div data-show-delay-ms="250" data-append-to-body="true" data-propagate-tooltip-mouseover-events="true" data-anchor-corner="bottom-left" data-enable-skip-handler="false" data-popup-corner="top-left"> </div>
</div>
<div class="AxqVh">
<div class="OPPzxe">
<div class="QcsUad BDJ8fb BLojaf sMVRZe hCXDsb wneUed">
<div class="usGWQd">
<div class="KkbLmb">
<div class="YJGJsb"> </div>
</div>
</div>
</div>
</div>
</div>
</div>
<div class="HWmS8">
<div class="kGmWO"> </div>
<div class="OwOEge">
<div class="cJ1Ndf"> </div>
</div>
</div>]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/3d-druck">3D-Druck</category>                        <dc:creator>nick22</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/3d-druck/schrittmotor-mit-hoher-beschleunigung-ausgewaehlt</guid>
                        <title>Implementierung einer Pause in einen GCode bei 3d-Druck</title>
                        <link>https://www.stepcraft-systems.com/forum/3d-druck/7749-implementierung-einer-pause-in-einen-gcode-bei-3d-druck</link>
                        <pubDate>Mon, 15 Jan 2024 16:26:53 +0000</pubDate>
                        <description><![CDATA[Moin,
ich versuche für ein 3D-Druckprojekt Pausen nach jeder Schicht in meinen Gcode zu implementieren. Dies klappt leider nicht so ganz wie gedacht. Habe es schon mit dem G4 Befehl versu...]]></description>
                        <content:encoded><![CDATA[Moin,
ich versuche für ein 3D-Druckprojekt Pausen nach jeder Schicht in meinen Gcode zu implementieren. Dies klappt leider nicht so ganz wie gedacht. Habe es schon mit dem G4 Befehl versucht aber dieser wird leider nicht erkannt. Ich benutze den Roboter UR10e von Universal Robots.
Weiß vielleicht jemand was es noch für Möglichkeiten gibt, eine Pause einzufügen? 
Danke schonmal im Voraus:)
Im Anhang ist die angesprochene GCode Datei (+Versuch den G4 Befehl einzufügen)]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/3d-druck">3D-Druck</category>                        <dc:creator>Fabian Hecker</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/3d-druck/7749-implementierung-einer-pause-in-einen-gcode-bei-3d-druck</guid>
                        <title>Was ist der Grund, warum die Temperatur des Schrittmotors des 3D-Druckers zu hoc</title>
                        <link>https://www.stepcraft-systems.com/forum/3d-druck/7722-was-ist-der-grund-warum-die-temperatur-des-schrittmotors-des-3d-druckers-zu-hoc</link>
                        <pubDate>Sat, 16 Dec 2023 07:09:16 +0000</pubDate>
                        <description><![CDATA[Die Temperatur des Schrittmotors wurde kurz nach der Druckzeit sehr hoch. Ich habe den Strom des Treibers angepasst, aber es hat nicht funktioniert. Was sollte ich jetzt tun?]]></description>
                        <content:encoded><![CDATA[Die Temperatur des Schrittmotors wurde kurz nach der Druckzeit sehr hoch. Ich habe den Strom des Treibers angepasst, aber es hat nicht funktioniert. Was sollte ich jetzt tun?]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/3d-druck">3D-Druck</category>                        <dc:creator>Nele</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/3d-druck/7722-was-ist-der-grund-warum-die-temperatur-des-schrittmotors-des-3d-druckers-zu-hoc</guid>
                        <title>Syntax Error</title>
                        <link>https://www.stepcraft-systems.com/forum/3d-druck/7622-syntax-error</link>
                        <pubDate>Sun, 11 Jun 2023 16:02:43 +0000</pubDate>
                        <description><![CDATA[Hallo,
bei dem einrichten von Curra gibt es den in der &quot;Erste Schritte&quot; beschriebenen Custom FDM Printer nicht . Es steht zur Auswahl Custom FFF oder Smoothi Custom Printer.
Wenn ich die T...]]></description>
                        <content:encoded><![CDATA[Hallo,
bei dem einrichten von Curra gibt es den in der "Erste Schritte" beschriebenen Custom FDM Printer nicht . Es steht zur Auswahl Custom FFF oder Smoothi Custom Printer.
Wenn ich die Testdatei Drucke gibt es bei beiden Druckern Syntax Error. Siehe Anlage.
Was ist zu tuen ?
MfG
Dirk<div class="wpforo-attached-file"><a class="wpforo-default-attachment go2wpf-inline-attach" href="//stepcraft-systems.com/wp-content/uploads/wpforo/attachments/50716/63203=17683-fehler.JPG"><i class="fas fa-paperclip"></i> <div class="wpforo-attached-file-img"><img class="go2wpf-inline-attach-img" style="max-width: 320px;max-height: 240px" src="//stepcraft-systems.com/wp-content/uploads/wpforo/attachments/50716/63203=17683-fehler.JPG" alt=""></div></a></div>]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/3d-druck">3D-Druck</category>                        <dc:creator>Dirk Theis</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/3d-druck/7622-syntax-error</guid>
                        <title>Verkaufe PH40 Set</title>
                        <link>https://www.stepcraft-systems.com/forum/3d-druck/7596-verkaufe-ph40-set</link>
                        <pubDate>Wed, 19 Apr 2023 16:31:04 +0000</pubDate>
ich habe nach kurzem experimentieren festgestellt, das 3D Druck für mich nicht interessant ist.
Ich werde beim fräsen und Drehen bleiben.
Daher würde ich mein 3D Druck Set abg...]]></description>
Daher würde ich mein 3D Druck Set abgeben (PH40 Druckkopf mit Steuerung, Filamenthalter, Heizplatte)
Also das ganze 3D Set aus dem Shop (Shop 649,-€)
Bisher gelaufen: 3-4 Stunden
Abzugeben für 500,-€ VB (Kauf Datum Dez/2022, also noch mit Garantie)
Anfragen per PM im Forum. ***Email-Adresse entfernt. Bitte keine persönlichen Daten veröffentlichen.***
Gruß Joachim]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/3d-druck">3D-Druck</category>                        <dc:creator>Joachim Grimm</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/3d-druck/7596-verkaufe-ph40-set</guid>
                        <title>Richtige höhe für erste Lage?</title>
                        <link>https://www.stepcraft-systems.com/forum/3d-druck/7513-richtige-hoehe-fuer-erste-lage</link>
                        <pubDate>Sun, 08 Jan 2023 12:50:43 +0000</pubDate>
wir haben seit kurzem einen den PH40-Druckkopf zu unserer D.420.
Wenn ich die Stepcraft-Anleitung lese, soll der Z-Nullpunkt folgendermaßen eingestellt werden: 
Düse ...]]></description>
                        <content:encoded><![CDATA[Hallo zusammen, 
Düse solange herunterfahren, bis ein Blatt Papier zwischen Düse und Bett "sanft" eingeklemmt wird, dann 0.1 mm nach oben fahren, und dort Null in Z-Richtung setzen. Das ist also knapp zwei Zehntel über dem Druckbett. 
Wenn ich mit dem Stepcraft-Profil in Cura den G-Code erzeuge, wird die erste Lage bei Z=0.3 mm gedruckt, dazu kommt dann das Zehntel Luft und die Papierdicke, die Düse hat bei der ersten Lage  also knapp 0.5 mm Abstand zum Druckbett. Soll das tatsächlich so sein? 
<pre>;Generated with Cura_SteamEngine main
M190 S50
M104 S200
M109 S200
M82 ;absolute extrusion mode
; aus Stepcraft Doku
G21
G90
G71 T1 M6
G92 A0
G92 A0
G1 F7500 A-4
;LAYER_COUNT:460
;LAYER:0
M107
G0 F900 X5.983 Y-35.416 Z0.3
;TYPE:SKIRT
G1 F7500 A0
G1 F750 X20.611 Y-31.496 A0.75554
</pre>]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/3d-druck">3D-Druck</category>                        <dc:creator>Tobias Edler</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/3d-druck/7513-richtige-hoehe-fuer-erste-lage</guid>
                        <title>Suche gebrauchte Drucker Einheit ph 40</title>
                        <link>https://www.stepcraft-systems.com/forum/3d-druck/7460-suche-gebrauchte-drucker-einheit-ph-40</link>
                        <pubDate>Mon, 07 Nov 2022 22:54:31 +0000</pubDate>
Ich will mal erste Erfahrungen im 3D Druck sammeln. Am besten auf meiner M700 wenn ich günstig drankomme. 
Also ich hätte Interesse wenn jemand verkaufen will. 
Grüße]]></description>
Grüße]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/3d-druck">3D-Druck</category>                        <dc:creator>Nicolas</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/3d-druck/7460-suche-gebrauchte-drucker-einheit-ph-40</guid>
                        <title>3D Druckkopf Alternative</title>
                        <link>https://www.stepcraft-systems.com/forum/3d-druck/7392-3d-druckkopf-alternative</link>
                        <pubDate>Wed, 27 Jul 2022 17:16:19 +0000</pubDate>
                        <description><![CDATA[Hallo allerseits!
Dieser Teil des Forums scheint mir etwas ausgestorben, aber ich versuche dennoch mein Glück: ich habe noch eine &quot;alte&quot; stepcradt die ich kaum noch benutze. Jetzt würde i...]]></description>
                        <content:encoded><![CDATA[Hallo allerseits!
Dieser Teil des Forums scheint mir etwas ausgestorben, aber ich versuche dennoch mein Glück: ich habe noch eine "alte" stepcradt die ich kaum noch benutze. Jetzt würde ich mich gerne am 3D Druck versuchen, finde aber den Kopf von stepcraft für über 500€ sehr teuer, wenn man bedenkt, dass es ganze Drucker für unter 200€ gibt!
Ist der Preis denn gerechtfertigt und wenn ja wie?
Gibt es günstigere Druckköpfe, die auch mit der Stepcraft funktionieren?
Hat da jemand Erfahrung?
Viele Grüße
Johnny]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/3d-druck">3D-Druck</category>                        <dc:creator>Joathan Vöhringer</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/3d-druck/7392-3d-druckkopf-alternative</guid>
