									Stepcraft SC100 Pinouts - Accessories				            </title>
            <link>https://www.stepcraft-systems.com/forum/accessories/3116-stepcraft-sc100-pinouts</link>
            <lastBuildDate>Sat, 06 Jun 2026 00:07:47 +0000</lastBuildDate>
                        <title>Stepcraft SC100 Pinouts</title>
                        <link>https://www.stepcraft-systems.com/forum/accessories/3116-stepcraft-sc100-pinouts#post-38107</link>
                        <pubDate>Tue, 03 May 2016 15:24:24 +0000</pubDate>
                        <description><![CDATA[if your using a UC100 and wire direct to the output then nothing will be isolated.
better solution is to use a UC300 - connect one port to the SC just like the UC100 and then use the othe...]]></description>
                        <content:encoded><![CDATA[if your using a UC100 and wire direct to the output then nothing will be isolated.
better solution is to use a UC300 - connect one port to the SC just like the UC100 and then use the other ports to connect to your hardware via breakout board with isolation.]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/accessories">Accessories</category>                        <dc:creator>Rory Stoney</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/accessories/3116-stepcraft-sc100-pinouts#post-38107</guid>
                        <link>https://www.stepcraft-systems.com/forum/accessories/3116-stepcraft-sc100-pinouts#post-38044</link>
                        <pubDate>Sun, 01 May 2016 18:01:48 +0000</pubDate>
                        <description><![CDATA[I don&#039;t know what a SC100 is but does this help you?
Page 17]]></description>
                        <content:encoded><![CDATA[I don't know what a SC100 is but does this help you?
https://www.stepcraft-systems.com/images/Service/EN-Operating-Instructions-SC2-v2.pdf
Page 17]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/accessories">Accessories</category>                        <dc:creator>Lasse Ryhänen</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/accessories/3116-stepcraft-sc100-pinouts#post-38044</guid>
                        <link>https://www.stepcraft-systems.com/forum/accessories/3116-stepcraft-sc100-pinouts#post-3072</link>
                        <pubDate>Sun, 01 May 2016 15:16:50 +0000</pubDate>
                        <description><![CDATA[Hi,
I&#039;m looking to add some extras to my setup, incluing a coolant solenoid and control of FRENIC Mini inverter for the ELTE Spindle I&#039;m using.
I&#039;m guessing the way to do this with the...]]></description>
                        <content:encoded><![CDATA[Hi,
I'm looking to add some extras to my setup, incluing a coolant solenoid and control of FRENIC Mini inverter for the ELTE Spindle I'm using.
I'm guessing the way to do this with the SC100 is to wire things up to the D Connector? If that is the case, does anyone know the pin outs? I'm guessing they are different from the pins that can be configured within UCCNC?
Many thanks in advance
Rob]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/accessories">Accessories</category>                        <dc:creator>Rob Spencer</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/accessories/3116-stepcraft-sc100-pinouts#post-3072</guid>
