									Cutter knife and... gum? - Custom Applications				            </title>
            <link>https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum</link>
            <lastBuildDate>Thu, 11 Jun 2026 01:35:08 +0000</lastBuildDate>
                        <title>Cutter knife and... gum?</title>
                        <link>https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26063</link>
                        <pubDate>Mon, 11 May 2015 23:17:18 +0000</pubDate>
                        <description><![CDATA[Ok, so I think that I will abandon my idea about cutting rubber.
Anyway I&#039;ve discovered something new about usage of the routers as cutters.
The idea of a post processor for G-code is go...]]></description>
                        <content:encoded><![CDATA[Ok, so I think that I will abandon my idea about cutting rubber.
Anyway I've discovered something new about usage of the routers as cutters.
The idea of a post processor for G-code is good, but probably the one proposed from Donek is suitable only for their tool, mainly 'cause of the particular geometry of the tool itself.
Just for the chronicles: today I've cut a 2mm thick plate of vulcanized rubber (german: Ebonit?) with a 2-flute, 1.5mm dia, carbide end-mill (I know, I'm crazy).
feed rate = 120 mm/min
doc = 0.5 mm
rpm = 7000
It cuts the rubber with zero problem (neither temperature problems nor sticky gum on the tool). The gummy is "pulverized" by the cutter and the quality of the resulting "cut" is not so bad (in my opinion). Obviously, trying to cut a soft rubber in the same way it's almost impossible.]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/custom-applications">Custom Applications</category>                        <dc:creator>Giulio Buccini</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26063</guid>
                        <link>https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26050</link>
                        <pubDate>Mon, 11 May 2015 15:55:19 +0000</pubDate>
                        <description><![CDATA[Looks really interesting. 
On the webpage of Donek Tools you can get a free tool (excel sheet) to convert the normal g-code to a version with adjusted radius in the edges. 
As well the...]]></description>
                        <content:encoded><![CDATA[Looks really interesting. 
http://donektools.com/free-cnc-router-software/links-2/
As well the tool is asking for a "swivel height". Maybe this tool is doing all the needed work?
Thanks,
Marco]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/custom-applications">Custom Applications</category>                        <dc:creator>Marco</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26050</guid>
                        <link>https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26049</link>
                        <pubDate>Mon, 11 May 2015 15:49:25 +0000</pubDate>
                        <description><![CDATA[That&#039;s nearly what this inkscape plugin for exporting to HPGL is doing. The part missing is the &quot;lift up but still touch the material&quot; is missing due to the fact that HPGL only knows 2 state...]]></description>
                        <content:encoded><![CDATA[That's nearly what this inkscape plugin for exporting to HPGL is doing. The part missing is the "lift up but still touch the material" is missing due to the fact that HPGL only knows 2 states "pen up" and "pen down".
For the procedure described by you, you'd need 3 states "pen up" (for moving to another line), "pen down" for cutting and "pen in the middle" :lol:  for doing the turn.
Someone from the german part of the forum who tried this inkscape plugin with foil said that it works fine. But of course this is not how to cut thicker material at all because the knifes blade might break.
Rubber ... I don't know ... maybe it does not break the blade, but minimum I'd expect is, that it will look ugly.]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/custom-applications">Custom Applications</category>                        <dc:creator>Andreas</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26049</guid>
                        <link>https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26048</link>
                        <pubDate>Mon, 11 May 2015 15:01:43 +0000</pubDate>
                        <description><![CDATA[I suspect that the steps I wrote are not completely correct. When the cutter is lifted up in A a little amount of material in the corner remains uncutted. mmmmmh....]]></description>
                        <content:encoded><![CDATA[I suspect that the steps I wrote are not completely correct. When the cutter is lifted up in A a little amount of material in the corner remains uncutted. mmmmmh....]]></content:encoded>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26048</guid>
                        <link>https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26047</link>
                        <pubDate>Mon, 11 May 2015 14:58:08 +0000</pubDate>
                        <description><![CDATA[The description of the SC dragknife reports: &quot;angular degree: 60, suitable for foils over 0,5 mm&quot;
But it&#039;s not clear if 1.5 mm of rubber can be cut or not. Mmmmh...
As I understand, the ...]]></description>
                        <content:encoded><![CDATA[The description of the SC dragknife reports: "angular degree: 60, suitable for foils over 0,5 mm"
But it's not clear if 1.5 mm of rubber can be cut or not. Mmmmh...
As I understand, the trick for the cutter in the video is to program movements in such way that knife can be rotated in any cut-direction.
For example, to make a 90 degree corner:
<div class="wpforo-attached-file"><a class="wpforo-default-attachment go2wpf-inline-attach" href="//stepcraft-systems.com/wp-content/uploads/wpforo/attachments/27920/20482=4882-drag-knife.jpg"><i class="fas fa-paperclip"></i> <div class="wpforo-attached-file-img"><img class="go2wpf-inline-attach-img" style="max-width: 320px;max-height: 240px" src="//stepcraft-systems.com/wp-content/uploads/wpforo/attachments/27920/20482=4882-drag-knife.jpg" alt=""></div></a></div>
0) the router reaches position A
1) the router stops
2) the router lift up the blade, but in such manner that the tip <u>still touches the material</u>
3) router makes a smooth rotation, dragging the tip of the blade in A and, at the same time, rotating the direction of cut.
4) the router reaches the B position
5) the blade is pushed down again
6) the router starts to cut along the new direction
The trick is to maintain the tip of the blade in contact with material so it can be rotated exploiting the offset (i.e. the horizontal distance between the tip and the vertical axis of the router)
As I can see, this movements can be programmed by custom G-code (obviously this approach holds if you have to do only few cuts, for complex shapes programming all the work manually it's a nightmare).]]></content:encoded>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26047</guid>
                        <link>https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26044</link>
                        <pubDate>Mon, 11 May 2015 14:13:15 +0000</pubDate>
                        <description><![CDATA[Wow .. that&#039;s cool then. So it must do tiny little movements while going down into the material?!
Well ... I think that this can&#039;t be done with Inkscape -&gt; WinPC NC toolchain, as the H...]]></description>
                        <content:encoded><![CDATA[Wow .. that's cool then. So it must do tiny little movements while going down into the material?!
Well ... I think that this can't be done with Inkscape -&gt; WinPC NC toolchain, as the HPGL-file does not support different heights. In the video it looks like there is one height for moving without cutting, one height for turning the knife and another height for cutting.
Maybe it works with Inkscape -&gt; EstlCAM ?-&gt;
and the feature to dive in?
Would be nice to have a file created by SheetCAM for analysis.  :whistle:]]></content:encoded>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26044</guid>
                        <link>https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26035</link>
                        <pubDate>Mon, 11 May 2015 08:36:23 +0000</pubDate>
                        <description><![CDATA[The tool in the videos is a little bit more professional. The cutter can be turned by software/controller. The SC cutting tool is turned while cutting by the cutting forces.
Pay attention...]]></description>
                        <content:encoded><![CDATA[<blockquote>The tool in the videos is a little bit more professional. The cutter can be turned by software/controller. The SC cutting tool is turned while cutting by the cutting forces.</blockquote>
Pay attention to the mother, who does not move. Therefore, it is a normal drag knife , similar to the SC.]]></content:encoded>
						                            <category domain="https://www.stepcraft-systems.com/forum/custom-applications">Custom Applications</category>                        <dc:creator>Gerald</dc:creator>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26035</guid>
                        <link>https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26034</link>
                        <pubDate>Mon, 11 May 2015 07:45:43 +0000</pubDate>
I did not te...]]></description>
                        <content:encoded><![CDATA[The tool in the videos is a little bit more professional. The cutter can be turned by software/controller. The SC cutting tool is turned while cutting by the cutting forces. 
I did not test it up to now, but Inkscape nowadays has a nice feature to export a file as HPGL. The export tool behind allows to do the correction for cutters that cut behind the center. This should give you a file where 90° turns produce real 90° corners. Maybe this together with a "dive into" to set the knife in the right direction would give the best results on the SC.
I am not sure how deep the SC cutter tool can go, but my gutt feeling tells me that 1.5mm might be too much. And with rubber I'd expect even more problems. If you have a look at the image of the <a class="go2wpf-bbcode" rel="nofollow" target="_blank" href="https://www.stepcraft-systems.com/en/accessories/insertion-tools/replacement-knife-carbide-knife">replacement knife</a>, you see that the sharp edge turns into a cylinder very fast. This would give you a lot of friction in rubber.]]></content:encoded>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-26034</guid>
                        <link>https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-1785</link>
                        <pubDate>Sun, 10 May 2015 23:43:24 +0000</pubDate>
                        <description><![CDATA[I&#039;ve no experience in using a cutter knife on a cnc-router, I hope that someone of you can answer to my question: it is possible to use the cutter provided from Stepcraft to cut a rubber-pla...]]></description>
                        <content:encoded><![CDATA[I've no experience in using a cutter knife on a cnc-router, I hope that someone of you can answer to my question: it is possible to use the cutter provided from Stepcraft to cut a rubber-plate 1.5mm thick?
I'm talking not about hard-rubber material (i.e. vulcanized gum) but flexible rubber with hardness around 60-70° Shore-A. In particular, I'm worry about making 90-degree cuts, how can it be done with a knife?
I found a video on youtube, here you can see the cnc-machine making cut that I want by simply lifting up and down the blade. It is possible to do something like that with the Stepcraft cutter?
<a class="go2wpf-bbcode" rel="nofollow" target="_blank" href="http://www.youtube.com/watch?v=bMoRUZnvbXw">Cutting Leather With The Donek Drag Knife</a>]]></content:encoded>
                        <guid isPermaLink="true">https://www.stepcraft-systems.com/forum/custom-applications/1811-cutter-knife-and-gum#post-1785</guid>
