Please help with questions on Stepcraft Milling Motor MM-1000 DI
1 Beiträge
1 Benutzer
3 Ansichten
(@behai_nguyen)
Hi, I am Be Hai from Melbourne, Australia. I am learning to build my own CNC using Mesa 7I96S and LinuxCNC.
I don't yet have a machine. But I have been able to run G-Code in LinuxCNC and get the 7I96S to turn on and off a normal Dremel and hand drill via a contactor.
I am thinking of using the Stepcraft Milling Motor MM-1000 DI https://stepcraft.com.au/index.php?dispatch=products.view&product_id=557 as the milling spindle.
My initial studies using free ChatGPT indicate that this is possible.
The Mesa 7I96S spindle interface works like a potentiometer. It has three pins:
- SPINDLE+ represents one end.
- SPINDLE- represents the other end.
- SPINDLE OUT represents the adjustable wiper.
The output voltage is controlled through an FPGA PWM generator.
The supplied voltage between SPINDLE+ and SPINDLE- determines the available analogue output range.
The manual specifies a supply range of 5–18 VDC.
For our application, we could potentially configure this output to provide 0–10 V.
This matches the MM-1000 DI's speed-control voltage requirement.
Please help me with the following two questions:
1. Does the supplied PWM converter accept a conventional PWM signal from an external CNC controller and convert it into the 0–10 V speed-control signal, or is it designed for a particular Stepcraft controller interface?
2. a. Can the MM-1000 DI be switched ON and OFF solely by applying and removing the 8–56 VDC PV interface supply (Pin 1), while keeping its 230 V AC main power connected?
2. b. Does removing this PV supply reliably stop the motor, without reverting to manual operation?
Please note, the 8–56 VDC PV is documented in Section 7.2. of https://stepcraft-systems.com/download/20230413_Betriebsanleitung_MM1000-1650DI_DE_EN.pdf
Thank you and best regards,
...behai.
Veröffentlicht : 25/11/2026 2:30 a.m.
