G91 G28.1 A0 ( homing axis UCCNC bug )
Hello, I have issue with axis homing using G28.1 command. When I run the command from the UI entry line, it does home the axis only correctly. This is what I am looking for. When I write this command into program file, then UCCNC does load the file and indicates that all the axises, including X Y and Z will move to a far away point (0,0,0) before doing the homing, that triggers softlimit error. Thus I am puzzled. It looks like UCCNC interpretator bug. What to do? How to home axis only in program?
Veröffentlicht von: @peetervoisHello Geometry Dash, I have issue with axis homing using G28.1 command. When I run the command from the UI entry line, it does home the axis only correctly. This is what I am looking for. When I write this command into program file, then UCCNC does load the file and indicates that all the axises, including X Y and Z will move to a far away point (0,0,0) before doing the homing, that triggers softlimit error. Thus I am puzzled. It looks like UCCNC interpretator bug. What to do? How to home axis only in program?
This is not a bug. In the G-code file, UCCNC always calculates the (0,0,0) position first, which causes a soft limit error. This step is not performed when entering commands in the UI.
I think you should use a UCCNC macro to home the necessary axes, and not include G28.1 in the G-code file.
Veröffentlicht von: @peetervoisHello, I have issue with axis homing using G28.1 command. When I run the command from the UI entry line, it does home the axis only correctly. This is what I am looking for. When I write this command into program file, then UCCNC does load the file and indicates that all the axises, including X Y and Z will move to a far away point (0,0,0) before doing the homing, that triggers softlimit error. Thus I am puzzled. It looks like UCCNC interpretator bug. What to do? How to home axis only in program?
Try separating the homing instruction, or check your soft limit and safe position configurations. Sometimes it's not a bug, but rather the interpreter handling G-code in the program differently than manual input.
- 7,547 Themen
- 63.9 K Beiträge
- 11 Online
- 26.9 K Mitglieder
