Software
2
Beiträge
2
Benutzer
0
Reactions
174
Ansichten
hello guys, i have stepcraft m700 and m500 , where the setting if im will use offset wear or use g42 ?
Veröffentlicht : 06/08/2026 2:47 a.m.
Hi, it depends on which control software you’re using with your STEPCRAFT M500/M700. If you want to use G42 with wear compensation, you generally need to enable cutter compensation in your CAM software and make sure the postprocessor outputs the correct G-code. G42 applies compensation to the right of the programmed path, while G41 applies it to the left. Which software are you using — UCCNC, WinPC-NC, or something else?
Veröffentlicht : 14/10/2026 3:01 a.m.
