UC100 + Low-Cost 5-Axis Breakout Board: My Stepcraft Upgrade Path
3 Beiträge
2 Benutzer
631 Ansichten
Wayne
(@wmorton)
I know this forum is mostly inactive. And that my Stepcraft D series 840 is now an old machine. However, i wanted to document some of my experience with replacement electronics as I really struggled to find any information out there. Hopefully this helps someone!
When my Stepcraft mainboard died, I wasn’t keen on paying Stepcraft’s replacement prices. Out of curiosity, I tried pairing a UC100 USB motion controller with a generic 5-axis breakout board (blue version, £5–10 on eBay). That was well over a year ago and it’s been rock solid ever since.
Why it works so well
  • The UC100 already handles the motion control, generating clean and reliable step/direction pulses (UCCNC/Mach3 compatible).
  • The blue 5-axis breakout board is a simple hub for signals, opto-isolated and easy to wire.
  • External drivers (TB6600 in my case) are cheap, replaceable, and easy to upgrade.
  • The system is modular, so I can swap motors, add axes, or run a laser without touching the "mainboard."
Upgrades I’ve made with this setup
  • Dual Y-axis motors (synced).
  • NEMA 23 motors on X and Y for more torque.
  • Upgraded NEMA 17 on Z.
  • Added a rotary axis.
  • Integrated a PWM-controlled 3rd-party laser (much simpler than wrestling with the Stepcraft laser module pinout).
  • Increased the power supply to 36V 10A, which gives the NEMA 23s much better performance.
  • Swapped microswitch endstops for inductive proximity sensors, which are more reliable and accurate.
  • Mounted all the electronics in a separate box outside the machine. Only two multi-core cables run to the Stepcraft (one for power, one for signals). This makes maintenance and troubleshooting far easier compared to the OEM setup.
Cost comparison (approximate)
  • Replacement mainboard: Stepcraft around £300–400. My setup orginal UC100 + breakout about £10.
  • Performance kit (dual Y motors): Stepcraft around £300. My setup two NEMA 23s, extra driver and wiring about £60.
  • 4th axis rotary kit: Stepcraft around £600. My setup NEMA 23, driver, chuck/rotary about £150.
  • Laser add-on: Stepcraft around £600. My setup third-party PWM laser about £50.
  • Individual driver replacement: not available from Stepcraft. With my setup, TB6600 driver about £12 each.
Overall, the savings easily run into hundreds and the flexibility is far greater.
Why I call it an upgrade
  • No more "all-in-one" lock-in. If a driver fails, I replace a £12 part instead of a £300+ board.
  • Easy to scale. If I want closed-loop steppers or bigger drivers I just plug them in.
  • Reliability is better, since the heat and load are spread across independent drivers rather than crammed into one PCB.
  • External mounting makes maintenance and upgrades simple and accessible.
  • The higher voltage supply gives noticeably more speed and torque headroom compared to the stock setup.
  • Proximity sensors are a big step up in accuracy and durability over the stock microswitches. (Sawdust on microswitches!!!)
Closing thought
This setup cost me a fraction of Stepcraft’s replacement parts, has run flawlessly for over a year, and allowed me to upgrade in ways Stepcraft never intended. I found very little online about people running Stepcrafts with UC100 + generic breakout, so I wanted to share my experience in case it helps someone else.
Any questions, let me know and I'll do my best to answer!
Dieses Thema wurde geändert Vor 1 Jahr von Wayne
https://mechape.co.uk/
Veröffentlicht : 27/09/2025 8:13 p.m.
Wayne
(@wmorton)
PS) anyone looking for this breakout board, just search something like "MACH3 5 Axis CNC Breakout Board. CNC, Router, Engraving Stepper Motor Driver."
I can confirm this works with UCCNC.
Veröffentlicht : 27/09/2025 8:16 p.m.
(@mr-smartyman)
thanks for posting this. There really isn't much information.  Are there any additional references you could recommend for someone starting this process?  My control board just died.
Veröffentlicht : 28/07/2026 11:42 p.m.
